Ir para o conteúdo principal
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
76 Perguntas Visualizar todos
Why can't I hear anything from my tablet?
I can't hear anything from my tablet and my volume is on max. I can hear just fine when my headphones are in though. Why can't I hear without my headphones?
Esta é uma boa pergunta?
Pontuação 10
6 comentários
Same problem. It starts out fine, but then fades until I hashes to turn it up all the way, regardless of whether using headphones or speakers. Worse, it often displays a warning about how listening at high volume can be harmful. I don't think this tablet is capable of producing dangerous volume. I can't hear it over the sound of of a quiet fan sometimes. I can usually fox the problem for a while by reseting the tablet, but that should not be necessary.
por
System sounds, although I have them set as low as possible, are often extremely loud.
por
Why don't i hear anything on my device?
por
To be honest I don't
por
Why can't I hear anything from my tablet I tried everything
I can't hear calls it's an app I have anyway I can't hear YouTube music vids I can't hear anything in general it's not just one app o can't hear it's EVERYTHING!!! Someone tell me what to do
por
Exibir mais 1 comentário
Adicionar um comentário
5 respostas
Pergunta mais útil
Why won't my tablet produce sound?
Following the instructions in the link above fixed my problem. I reset my tablet, and as soon as the screen went dark, I pressed the volume up, and held it until it finished reseting. Then I was able to turn up the volume from all the way down, to a reasonable level about half way up, which is much louder than I've ever been able to set it before.
Esta resposta foi útil?
Pontuação 1
The speakers are probably not working properly. Check out the the speaker replacement guide for more information.
Pontuação 0
1 comentário:
It is likely your speakers require replacement. However, to be certain you should follow the steps in the troubleshooting page.Samsung Galaxy Note 8.0 Troubleshooting
por
I can't hear anything on my tablet and it is at the top volume, I also can't hear it when my headphones are in what do I do to fix the sound?
Pontuação 0
Why can’t I eat anything out of my tablet
Pontuação 0
Why can’t I hear anything out of my tablet
Pontuação 0
Adicionar a sua resposta
Jon Morgan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 9,989
