Ir para o conteúdo principal
Pergunta encerrada
Recover lost text messages on iPhone 6
The upgrade process was failed when I was trying to update my iPhone 6 Plus to iOS 8.1 early this morning. I had to manually download the image and install it on my iPhone via iTools. I can restore content stored on iCloud backup, such as photos and notes, but I couldn't get back my text messages and voice memos, which are important for me. How to recover my lost messages? Cn any recovery app do the job for me? I am curious about that.
Esta é uma boa pergunta?
Pontuação 6
14 comentários
While if you don’t have any backup files in iTunes or iCloud, can you recover deleted text messages on iPhone? The unique way is to recover with PhoneRescue.
http://www.data-recovery-iphone.com/reco...
Step 1. Connect your iPhone to the computer and Run PhoneRescue.
Step 2. Click "Start Scan" > Scan data on your iPhone quickly.
Step 3. Preview and select contacts you need.
Step 4. Click "Recover" to recover them.
por
As mentioned by Tom Chai your text messages are also a part of iCloud backup. So you should check your iCloud backup again.
Three days back, I also lost few important text messages while jail-breaking my device. I found this guide on Google search http://www.easyphonerecovery.com/how-to-... and it helped me recover my text messages to some extent. It's not a free tool/app and as a matter of fact all the iPhone data recovery products are !&&* lota expensive.
por
iPhone data recovery is designed specifically that can help you retrieve erased photos, videos, contacts and messages contact the historical past, information, for example. from iphone immediately or remove backup data files from iTunes And iCloud to bring back erased docs, to guarantee that it can save you them on your hard drive or Macintosh with one specific just click.
http://www.freeiphonedatarecovery.com
por
Generally, iCloud also backs up text messages and voice memos. I’m not sure why you cannot restore the text messages and voice memos using the iCloud backup files.
If the lost data haven’t been backed up, you can still recover the deleted files by scanning the iPhone directly using the third-party iPhone data recovery utility:
http://iphonedatarecovery.aolor.com/
por
The best and famous iPhone messages recovery tool.
http://www.any-data-recovery.com/iphone-...
por
Exibir mais 9 comentários
Adicionar um comentário
26 respostas
Pergunta mais útil
The technology has come a certain way, there is now an app approved by apple on the App Store that restores deleted data back to your iPhone
When you delete data from an iPhone, the deleted data still remains on the iPhone's database and can be recovered by various types of smartphone recovery software.
It is recommended that when you delete items from an iPhone by mistake, or if an iOS update deletes your data, that you stop using your iPhone until you recover the deleted data. This way you will lessen the chances of you overwriting the deleted data by creating new content on your phone.
Smartphone data recovery software is out there, you just need to do a quick search, read reviews, check prices and make a choice.
Good Luck :-)
Esta resposta foi útil?
Pontuação 7
5 comentários:
As mentioned by someone here, I tried this desktop-utility http://www.easyphonerecovery.com/how-to-... and it helped me recover deleted threads of text messages on my iPhone 6s. Except some business-related text conversations most of them were useless. But yeah this tool does work.
por
Three Solutions for iPhone Data Recovery 1. Restore from Backup - If you have backup for your personal data on iTunes, you can restore from the backup. 2. iCloud - If you have enabled iCloud, every time, your iPhone is connected to Wifi and a power source, and the screen is locked, iCloud will automatically backup your data. So that you can easily recover wiped iPhone data. 3. UFUSoft Fonelab - If you don't backup your files on iPhone previously, then this software might be tough to recover. And by using this third party iPhone data recovery software, you can recover data from iPhone with ease on computer. http://www.data-photo-recovery-software....
por
You can use this software tool here and it worked really well for me. Here is the link: http://recoverdeletedtexts.com Hope it helps. It's free btw.
por
We should get back the lost message as soon as possible.Otherwise it may only be restored through iCloud backup.
Hope it helps.
https://www.doctor-telephone.com/iphone-...
por
Have you created an iTunes or iCloud backup before? Restore the backup if you have one. You can also recover deleted messages from iPhone with an iPhone Data Recovery directly without backup. The program also allows you to extract SMS from an iTunes backup without restoring the whole backup on your iPhone.
https://www.forecovery.com/iphone/recove...
por
Those contents are included in iCloud backups, but if you didn't choose to back up those data, it's literally impossible to recover them. All data stored in the iphone is encrypted and during recovery process the encryption key is destroyed to instantly destroy all data, preventing any potential personal data leaks.
Pontuação 4
3 comentários:
I can't find text messages option via iCloud panel or on my iPhone
por
It's included already.
por
Tom, I selected to backup my data on my iPhone too, but whenI log into myiCloud on my laptop, Texts/ Messages is not an option. How do I access my texts thru iCloud if the icon isn't there?
por
No matter you made backup or not, now iPhone data recovery can recover the lost text messages on your iPhone.Here is a tip for you to recover deleted text messages from iPhone directly and restore SMS from iTunes backup.
How to Retrieve Deleted Text Messages on iPhone
But an important thing you should remember: once you delete important text messages on your iPhone which you did not backup to iTunes or iCloud, stop using your iPhone at once for any new operation may generate new data and overwrite the deleted text messages. If this happens, you cannot recover the lost sms from your iPhone with the latest iPhone data recovery.
Pontuação 4
Best bet is to just restore your phone from a backup as Meg St. Clair suggested. You can also just Google some third-party recovery tools and see if you have any luck with them. Decipher Text Message has a recovery feature as do other programs that I've used the past for data recovery. It can be hit or miss as to how much lost info you can recover.
Pontuação 4
You are still able to recover deleted text messages from iPhone even if you have no iTunes or iCloud backup files. The free trial of FonePaw iPhone Data Recovery enables you to preview all the found text messages (including the deleted ones) after the scanning, and you can recover all of them.
You need to register it only if you want to save the found messages to your computer or transfer back to the iPhone.
Best Wishes.
Pontuação 1
Hello! I think this iPhone 6 Data Recovery for Mac can help you . I ever use it to recover contacts, photos from my iPhone 6 on Macbook! More detail:[ http://www.tenorshare.com/products/iphon...| http://www.tenorshare.com/products/iphon...]
Pontuação 1
Vibosoft iDataRescuer is a powerful program to help users easily recover lost data from iPhone/iPad/iPod device or iTunes backup file without any loss.
http://x.co/7ug44
Pontuação 1
Hi, guirupa
I don't know why you could find photos and notes from iCloud backup but couldn't find text messages, but you may try Tenorshare iPhone 6 Data Recovery app, this is the world's first data recovery tool support iPhone 6 Plus and iPhone 6, and it did a good job on my iPhone 6 Plus.
This tool provides 3 recovery modes: iTunes, iCloud and recover data from iPhone directly. I suggest you can try the iCloud recovery mode to find your lost text messages frist, and the iOS device recovery mode also great for you.
And don't worry, it compatible well with iOS 8.1
BTW, if you're using Mac, just choose the iPhone 6 data recovery software for Mac.
Pontuação 0
If you want to save time and get back your lost text messages on iPhone 6 Plus, then you can consider an iPhone 6 Plus data recovery software
Pontuação 0
If you can't restore the deleted data from backup, you can recover the data from iPhone without any backup (iTunes or iCloud backup) but this needs you to pay for a professional iPhone data recovery tool.
Try this one and download the free trial to preview the lost data before registering to recover iPhone 6 lost messages and voice memos.
Pontuação 0
If you did backup SMS to iTunes, you can easily restore from iTunes backup, but if you did not make backup, you do not need to worry, there isa tip to recover lost messages from iPhone without backup. iPhone data recover can help you.
Pontuação 0
How to retrieve deleted text messages on iPhone 6, iPhone 6 Plus- https://www.youtube.com/watch?v=BsDvqkqm... YouTube video guide for iPhone 6 text messages recovery options
Pontuação 0
As far as I know, there are 3 free ways you can try to retrieve photos from iCloud, from iTunes backup files, from iCloud backup files and from iPhone directly. And another popular and easy way to recover deleted pics is using recovery software, such as iPhone Data Recovery.
Pontuação 0
I learn this way to retrieve deleted text messages on iPhone on pcadvisor.co.uk.
1. Connect your iPhone to the PC with which you sync it. iTunes should open (if not, open it manually).
2. You should see your iPhone in a box, top righthand corner. Select it.
3. Now choose 'Restore backup'.
4. All the data you previously backed up will now replace the data on your phone. It will take a few minutes. As long as you haven't backed up subsequent to deleting those text messages, they should now appear on your phone handset.
Pontuação 0
Deleted some data by accident? How to get back lost iPhone data? Well, now I'll recommend Coolmuster iPhone iPad iPod Data Recovery software for you.
Pontuação 0
2 comentários:
Recover lost data including text messages on iPhone 6:
http://x.co/69v2w
por
For Mac users, here's also a guide to help you backup iPhone messages.
Pontuação 0
Besides iOS update, text messages can get lost owning to:
1. Wrong operation, e.g. mistaken deletion of text messages;
2. iPhone Jailbreak;
3. iPhone factory settings restore;
4. iPhone has been lost or stolen;
5. iPhone was damaged, broken.
No matter you have created backups of your iPhone or not, here in this guide you will get three ways to retrieve the deleted messages from iPhone 6/5C/5S/5/4S/4 with the help of an iPhone data recovery tool - PhoneRescue.
Resource from:http://www.imobie.com/support/retrieve-d...
Pontuação 0
The Solutions I am aware of:-
1. Restore your iPhone with the backup file you've made before the jailbreaking.
2. Try Dr.Fone for iOS. It allows you to retrieve text messages and contacts from your iPhone, iTunes backup file or iCloud backup file and save them to your iPhone again.
Pontuação 0
Here is a solution to offer two modes to recover iPhone data including messages.
iPhone Text Message Recovery tool
Pontuação 0
Have you ever backed up your messages in iTunes or iCloud?
If you have backed up in iTunes or iCloud, FonePaw iPhone Data Recovery can help you scan those backups to get your messages back;
However, if you have no backups available, you need to connect your iPad to your computer, so that it will be detected automatically by FonePaw iPhone Data Recovery, and then you can get a scanning result of all the data, you can recover deleted text messages from iPhone there.
Pontuação 0
Hey,
Actually you have 3 ways to recover your lost sms from your iphone 6.
iTunes backup file, iCloud backup file and recover from your iOS device directly.
For first two ways, you need to have the backup file from iTunes or iCloud. If you do not have the backup file, the only way to recover lost text messages from iPhone is to recover from the device. iPhone Data recovery software may help you to do that. All the software you can find online claim that they can recover your delete/lost sms from your iPhone. However, not all of them work like they said on their website. I have tried some of the recovery software online and find this guide, I think it is the best one for now.
http://www.iphone-datarecovery.com/recov...
Pontuação 0
Actually, all lost or deleted contacts still on your iPhone,you can recover iPhone contacts with or without iTunes backup!
There’re two ways for you restore iPhone contacts:
1) iTunes can automatically back up your iPhone contacts and update it every time when you sync it,however,you can extract iPhone contacts from the iTunes backup when you lost your iPhone.
2) All contacts stored on iPhone are covered and rewrited no matter you deleted them or lost for some reason,to recover contacts from iPhone directly,you must to use a professional iPhone contacts recovery tool.
Here's a method for you:
recovery-android.co m/recover-contacts-from-iphone.htm l
Pontuação 0
To use a call MobiKin Doctor for iOS to recover lost text messages from iPhone 6. Here you can through three step to restore lost text messages from iPhone 6.
Step 1: Run the program and choose a mode
Step 2: Preview and choose text messages
Step 3: Recover lost text messages from iphone 6
Read more: How to recover deleted text messages from iphone
Pontuação 0
You can recover lost text messages on iPhone 6 by following 3 ways.
1. Restore the deleted SMS from iCloud if you have done some backups before.
2. Extract everything from an iTunes Backup if you have synced text messages to iTunes before.
For above methods, you can follow the official tutorial for more details:
https://support.apple.com/en-us/HT203977
3. If you do not have any backup files and haven't overwritten data, text messages may still stored in a database format. There is still a chance to recover them by some third-party tool like iPhone Data Recovery by directly scan.
Pontuação 0
If I buys a iphone 6 and have backup iphone messages and contacts to itunes and icloud .But I no idea how to extract iphone messages from itunes . With my friends recommend ,I tried Coolmuster iPhone Backup Extractor to extract iphone data from backup. Works well!
How to recover deleted sms from iphone 6
Pontuação 0
As I opened my iPhone 6 there was already a message on the screen. I swiped the "open spot"before I completely read it. Now I can't find it.
Pontuação 0
2 comentários:
How do I find it
por
With the help of FoneLab for iOS, you can easily retrieve deleted text messages from backups or from the iPhone directly. Read here for more information. http://www.fonelab.com/resource/retrieve...
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 231,686
