Ir para o conteúdo principal
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
59 Perguntas Visualizar todos
How do I repair a cut headphone cable?
The cable of my Apple EarPods got cut above the mic. I'd usually be able to repair a cable, but because everything inside is so tiny, I can't really tell what's what. Is there a way to repair the cable?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
So did the volume button get cut off?
por
No, it was cut above the volume button and microphone. There are only two wires inside the cable, they look like they're wound around a small string, I can't see any insulation, just two differently colored wires.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes there is 2 different coloured whiers
Twist the one colour to the corresponding colour other whier.
Heat it carefully.
Then apply a few drops of solder to get it properly.
Cover the whire in electric tape.
Do the same for the other.
Tape the hole thing together.
Hope this helps
Truls
Esta resposta foi útil?
Pontuação 1
4 comentários:
Thank you, I'll try that!
por
Did that work???
I tried for Sennheiser Ear phones.. But it didn't...
I have joined Red and Green as one and the other Copper wires as one.
Please let me know if I am doing wrong.
por
My iPhone cables are damaged below mic what should I do ?
por
I Have A Minor Cuts Becoz Of That I Have To Insert My Earphone For 5-6 Time To Enable My Microphone.Becoz My Microphone Doesn’t Start
por
Adicionar a sua resposta
Sophia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 45
Últimos 30 dias: 103
Duração total: 16,459
