Home button sticking after screen replacement
After sitting the screen down fully the home button sticks. When i lift the glass up a fraction it doesnt stick but when i seat if flush it sits.
Any ideas?
Esta é uma boa pergunta?
Any ideas?
I've found the metal frame under the home button to be causing the issue. Slightly bend the frame away from the home button and it should work properly
Esta resposta foi útil?
Seen this issue once before and I just took the plastic button off the original and fitted to the new glass being careful when lifting up the home flex and then worked 100%
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 1,766
