One channel is not recording properly. Can I fix it?
The L channel input isn't working. It seems to be picking up some low levels signal of some sort every now and then, and on playback there appears to be an almost silent low level recording, but the usable recording is effectively mono (R channel only)
I've opened it to try and see if there is a loose connection, but there is none that I can see, which makes it seem like the problem might be electrical / with the logic board.
Is this fixable at all? And if so, how?
And, if not by me, then where could I send/take it to be repaired? (I'm based in London)
The recorder is no longer under warranty, but I really don't want to have to trash it / replace it with a new one. I'm positive there must be some way of repairing it. Really hoping the answer can be found in this helpful forum!
Esta é uma boa pergunta?
1 comentário
My R channel is not working. How do i solve it. Suggest me.
por miliprakash72
