My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
Esta é uma boa pergunta?
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
Esta resposta foi útil?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 1,677
