Ir para o conteúdo principal
Possible to swap entire screen with MBP 2.0 Core Duo?
I have been blessed by the hand me down gods with both a core duo 2.0 and a core 2 duo 2.33. The 2.0 has issues, however, and is destined foe eBay. It does have an excellent screen, though, and the only issue with the 2.33 is noticible dimness in the center of the screen on startup or wake from sleep (weak backlight, I surmise). The most appealing and easiest of repairs would be a complete screen swap, housing and all. Anyone know if this is possible? I'm concerned with the wireless antenna, does that need to be swapped, too? Thanks in advance.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes, according to the product page, the two are compatible, use this guide to take it out and this guide to install it.
Imagem de MacBook Pro 15" Core Duo Model A1150 LCD Panel
Guia
MacBook Pro 15" Core Duo Model A1150 LCD Panel Replacement
Nível de dificuldade:
Muito difícil
Imagem de MacBook Pro 15" Core 2 Duo Model A1211 LCD Panel
Guia
MacBook Pro 15" Core 2 Duo Model A1211 LCD Panel Replacement
Muito difícil
Esta resposta foi útil?
Pontuação 1
1 comentário:
Adicionar a sua resposta
stevesontheroad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 671
