Does the iPhone 6 have a Liquid Contact Indicator?
Did Apple put Liquid Contact Indicators in the iPhone 6 or 6+?
From the tear down images I've seen I don't see one.
Esta é uma boa pergunta?
Yes, on the tip of the logic board.
Esta resposta foi útil?
Interesting. I have not noticed it. So a Genius would have to lift the screen to check this indicator. Thanks.
The external LDI is located in the SIM card Slot.
The only External LDI indicator for the Iphone 6/6P is in the SIM card slot. It is hard to see on the darker models. It is located on the case tucked behind the inner edge of where the SIM trey slides in.
Yes. And when you fish one out of an RV toilet it is bright red. It is pretty easy to lift the screen of the 6 and even without a sticker water damage is obvious.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 67,767
1 comentário
I have the same problem. Went to exchange my phone and they could not accepted because they could not see the external LdI in the sim slot. I tried to find it at home using the auricular small tip with light and did not see it. I even tried using the digital with camera with no luck.
por Sonia Cubero
