Ir para o conteúdo principal
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
How do you remove LCD from case
It looks like around the hinge the LCD casing is broken. I would like to replace the casing without replacing the whole LCD.
How do I open the casing so I can see which side is broken.
I can be reached at
Thank you for your help
Erik
Esta é uma boa pergunta?
Pontuação -1
1 comentário
machead3
Great Link
It's exactly what I needed
Thank you
por
Adicionar um comentário
2 respostas
Solução escolhida
Once you get the top off the bottom
It should be very evident which one is broken see: http://www.PowerBookmedic.com/mac-repair... Display removal followed by hinge replacement.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Esta resposta foi útil?
Pontuação 2
It's a difficult repair to replace the LCD casing on the PB Titanium since it is glued to the LCD and hard to glue it back in place. You could find a whole replacement display assy for cheap if you search the web (ebay, craigslist, etc).
Pontuação 1
Adicionar a sua resposta
Erik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 1,928
