Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
What is this part?
I can't figure out what this part is. I am replacing the upper case on a macbook pro. Look at this guide:
MacBook Pro 13" Unibody Early 2011 Upper Case Replacement
In step 36, you can see it. It is under the right speaker and it looks like a flat plate with an antenna wire attached to it. My new case didn't include this part and it doesn't seem to come off of the case.
Can anyone tell me what this is?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
That is a ground for the antenna. It should come attached to the top case but can be removed by taking out the small screw that is at the top of it, but it also may be attached with adhesive. (I am a former apple tech and never actually removed it due to it always shipping attached to the new top case.)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks plam.
por
Adicionar a sua resposta
stdonato será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 50
