Ir para o conteúdo principal
The Lenovo IdeaTab A2109 is a 9-inch multi-touch screen tablet released on August 27, 2012.
My tablet wont boot or charge
When i plug the tablet into the charger there is no response and when i try powering up i get a quick flash and vibration alhough it doesnt boot up, i have tried holding the volume+ and pressing the power button for different lengths of time and still nothing, the product is a little over a year old, it is a 'lenovo tablet pc ideatab A2109A-F' model:2290, any help would be great thanks.
Esta é uma boa pergunta?
Pontuação 8
Adicionar um comentário
9 respostas
Pergunta mais útil
i have same problem
Esta resposta foi útil?
Pontuação 1
I have the same problem
Pontuação 1
my tab is continuously booting. how to stop that
. lenovo idea A2109A model
Pontuação 0
1 comentário:
Had same with A3300-hv just press volume up and down and power off button together it will work for booting
por
MY Lenovo IDEATAB A2109A is booting continuously when i swictedon and iam unable to any program with that pls help me to resolve this problem
Pontuação 0
The problem could be you battery or io port if you don't feel vibration. Its possible that the screen might not work too.
Pontuação 0
I have this same problem and everything I try to do it just doesn't work
Pontuação 0
my screen wont turn on or take charge any more
Pontuação 0
Has anyone thought to check the USB charge port by wiggling(GENTLY) . to see if a solder contact has failed???????
Pontuação 0
Hello! First try charging for 5 hours after doing it while plugged press volume up and down and power on/off button together you will get a vibrate ! . its a good sign. Try again for 30 seconds . Hopefully this will work!
Pontuação 0
Adicionar a sua resposta
che gee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 36
Ao todo: 3,371
