Ir para o conteúdo principal
A segunda geração do iPad com modelos Wi-Fi, GSM e CDMA. Alguns modelos foram atualizados antes do iPad 3. O reparo é difícil e requer procedimentos de calor e separação.
730 Perguntas Visualizar todos
How to fix green/purple screen
I am in the process of a ipad 2 screen repair and I have two brand new lcds. For some reason one displays a tinted green and the other tinted purple, I have tried every method I know to resolve this problem. Now im looking for advice on what causes this issue. Would great if I can resolve this today
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
5 respostas
Solução escolhida
Since no answer has been accepted yet, let me share my experience:
A/ First thing I try is disconnect then re-seat the Display Cable on both ends (using this guide): on the logic board and on the LCD. Then secure the connectors with Kapton/Polyamide tape.
B/ I test the contraption by:
1/ Gently re-seating the LCD back in place then flipping it again out of the back-case. In other words, I am causing the display cable to twist slightly and gently, and putting light stress on both connectors, to see if the change in hue occurs again. Please be gentle ;)
2/ Tapping slightly on the back of the iPad, especially around where the display connectors are located.
C/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
D/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the display cable.
E/ I test again (repeat B)
F/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
G/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the LCD.
From experience, 95% of cases are resolved without having to change the LCD.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Hello I good smack on the rear case will fix a wonky coloured display..
Same thing happened when I was repairing one today even after a reseed of the connector it was a green screen. So I lifted it up and hit it a smack on the back and normal screen functioned..
Pontuação 3
6 comentários:
Thanks for answering, ill give it a try tomorrow
por
Cheers keep us updated
por
Still not working I tried your method. Its not a loose connection or a grounding issue so I'm stuck
por
If a really hard good smack does not work then it needs opened up and the lcd disconnect and reconnected if still a funny display after that then the lcd has gone bad
por
I tried 2 lcds. One shows purple and the other shows green. The only thing I haven't tried is to restore the firmware.
por
Exibir mais 1 comentário
I went to the Apple Store and they took out my screen
Pontuação 0
The screen on my Apple IPAD2 changed from blue to pink/purple. Please help me with this problem.
Pontuação 0
Hi,
Usually that problem is due to a bad connection of your iPad's LCD, what has to be done is:
- turn off your iPad;
- open your iPad (please watch the repair guide related to it);
- carefully disconnect (on both ends) the flex cable shared by the LCD and the Logic Board;
- carefully reconnect it, make sure it is well connected;
- try turning on your iPad to check that it is working properly.
If not than you should need a new LCD.
Hope it helps :)
Pontuação 0
Adicionar a sua resposta
matthewlevy300 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 28
Últimos 30 dias: 75
Duração total: 29,826
