Is it possible to replace the SSD with higher capacity?
I have an Acer Chromebook CB5-311 16GB version and I was wondering if it's possible to replace the original SSD with a higher capacity one - also which type would fit?
Esta é uma boa pergunta?
Yes It is possible to replace your SSD with a higher capacity one. To my understanding, replacing your SSD with a higher capacity one is possible as long as the voltage ratings are suitable. Try some brands like Samsung or crucial !
Esta resposta foi útil?
All SSDs are the same physical size. The process is: you have to clone what is on your small capacity drive onto your new higher capacity drive. The higher capacity drive will accept the results of the cloning. Since the cloned drive will be an exact copy of your smaller capacity drive you will now have empty space left over. Your system can't use this until you link the empty space with the allocated part of the drive.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 1,055
2 comentários
i want to do the same thing, would love to know if anyone has done it yet?
por mahaba6
por mahaba6
