Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
20 Perguntas Visualizar todos
Pergunta encerrada
Hard drive cable unidentified part in delivery
I'm replacing the hard drive cable. Removed cable according to guide. See part# 605-3260 included but nothing in guide for its placement and part not seen anywhere within exposed areas around removed hard drive cable. What is it and what am I supposed to do with it? Can't see how to upload photo.
Thanks
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Part is a 1" square adhesive paper holding 5 rubber? strips
por
Adicionar um comentário
1 resposta
Solução escolhida
Take a look at the step 7 in this tutorial.
http://www.dannydullin.com/mbp-13-inch-2...
This is a rubber spacer. You have to place it on the hard drive bracket. This will separate the bottom cover from the cable and prevent another damage.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 185
