Trying to remove the back on a Dakota Fob watch
I have a Dakota Fob Watch and am tying to remove the back to replace the battery. I have proper tools but am not sure how to go about it. Any help would be appreciated
Esta é uma boa pergunta?
Is it a screw back or a snap back? Screw back should have at least two small notches on the back. You can use a small flathead, spudger, or a case wrench to open it. Insert it in the slots at the same time and turn counter clockwise. Snap back can be opened with any of the same tools inserted in the notch between the watch and the back case. Give it a little lift and it should pop right off. This link goes into more detail about the battery replacement. http://www.ehow.com/how_6466795_replace-...
Hope this helps! ~GG
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 95
Ao todo: 14,257
