Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Pergunta encerrada
Proximity Sensor Black Rubber Cover How To Put ON
While doing a screen replacement I noticed a small black rubber that fell off from the front camera proximity sensor area.
Can anyone tell me how to put the rubber piece back on.
A picture of how it is supposed to look or a clear explanation will be appreciated. Thank you.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Try this picture - http://ctpc.biz/5c-rubber.jpg
Hope it helps.
por
Thank you Paul. Your picture solved my problem, it is exactly what I was looking for. It will also help someone else if they encounter the same problem.
por
Adicionar um comentário
1 resposta
Tried placing the rubber over the sensor to see which way it would fit?
But to be honest, you can get away with it, done a friends 5s and he was picking bits up and dropped thay rubber part. Couldn't find it, so refitted everything withouy the rubber and everything works fine and still has after several months
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 923
