Ir para o conteúdo principal
The first tablet from Acer's Iconia Tab B1 family, Acer Iconia Tab B1-A71 was announced in January 2013.
Why is my picture in negative
My acer tablet has not been dropped or damaged to my knowledge. When I turn it on, the colour is all in negative. I've tried resetting and even just a simple turn off and on. Does anyone know if this can be sorted or does it need to be repaired by a professional.
Any help will be grateful
Thankyou
Esta é uma boa pergunta?
Pontuação 3
3 comentários:
same goes to me. i didnt dropped it and when i turned it on after charging all the pictures turn negative.
por
have you tried to go to settings - Accessibility - Negative Colors
por
Yes I have tried setting_accessibility. But could not fine negative colors....
por
Adicionar um comentário
2 respostas
You will need to turn of color inversion. Go to settings, click accessibility, scroll to the bottom, then click color inversion. That should fix it!
Esta resposta foi útil?
Pontuação 0
Most likely you have cracked resistor at lcd flex cable
You need to replace it with working one
https://imgur.com/a/3W99K
Pontuação 0
Adicionar a sua resposta
Gemma será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,347
