Ir para o conteúdo principal
The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Perguntas Visualizar todos
My iMac is ALIVE
My iMac is weird. I have recently got an iMac g5 from a friend who didn't use it so he had no problems. I am now having problems now with it. Sometimes it will wake up from sleep mode and will have a black screen, fans will be very loud. and will not respond from anything. When I do a hard shut down (pressing the power button till it shuts off). Once off I boot it back on and everthing works. I recently brought it to apple and they said that my month old hard drive (I replaced it to try and solve this problem) needed to be replaced and they also said to keep a record of when this occurs and this was on the dates that have occurred recently.
3-2-10
3-20-10
4-03-10
4-24-10
4-26-10
5-1-10
5-23-10
5-31-10
5-31-10 (not a typo happended twice)
If you have any ideas on why this happens or how to fix it, I would appreciate an answer.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Open it up and look at the capacitors for bulging and/or corrosion. Here's a nice reference Q&A: A couple of capacitor questions......
Esta resposta foi útil?
Pontuação 1
1 comentário:
I wondered if it might be that. + Ralph
por
Before you open it up
you can change the energy saver preferences Some have found that the changing the computer sleep and display sleep "never" settings works.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Pontuação 0
Adicionar a sua resposta
twila582 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,086
