Ir para o conteúdo principal
iPhone 5 stuck in not restoring DFU mode!
Hi,
I have an Iphone 5 (A1429) that randomly went into dfu mode... I wasn't able to get out of DFU nor do a restore (itunes would hang on "waiting for device").
After charging the battery for a night (it gots charge now, checked it with voltmeter) i got it to a stage where it is dispaying the itunes logo with usb cable (recovery mode) but i can't get out of that either (tried holding home and power for 10 sec, restarts and goes back into the same recovery mode)
if i connect it to Itunes now, i get it to actually starting to restore but 10 seconds after the status bar displays on both my laptop and iphone, itunes stops with error 14. I already tried re-installing itunes, deleting old IPSW and tried other wifi/ computer. I'm desperate so pleas help, i'm willing to open up my IPhone and i'm in possession of a mac, windows and ubuntu PC.
here is the log i get (only error section):
[15:25:29.0492] Failure Description:
[15:25:29.0492] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 14
[15:25:29.0492] Depth:1 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 14 - Failed to handle data request message)
[15:25:29.0492] Depth:2 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 14 - Failed to handle image request)
Esta é uma boa pergunta?
Pontuação 16
8 comentários
This question was migrated from http://meta.ifixit.com/Answers.
por
here is full itunes log...
http://pastebin.com/NMKaz53j
por
also,
my battery is giving me 4.25 volts on outer connections of the battery, is this enough? (i charged it 2 full nights...)
por
Same thing with me til this day anyone can help?
por
I know a free and safe tool that can help you kick out of iPhone duf mode with one click without iTunes. No need of home/lock button, only with one click, you can enter and exit iPhone mode.
por
Exibir mais 3 comentários
Adicionar um comentário
10 respostas
Solução escolhida
I just fixed the problem...
on 3 windows pc's it gave me error 14, i tried a million times...
i tried it on my friends MACBOOK and it worked first time!
weird that apple doesn't make itunes on windows so it would be the same as mac...
Esta resposta foi útil?
Pontuação 6
6 comentários:
Awesome! I'm glad it all worked out for you! Don't forget your solution incase it ever happens again! Cheers!
por
Lucky you. I did it hundred times on a PC and hundred fifty times on a Mac and still the same result. The phone hangs itself before it should start to suck the new firmware.
por
I'm genuinely going to cry if this doesn't work again. Because right now i need my phone as it has a load of my art project ideas on it and i need to do homework for tomorrow. this isn't even funny anymore.... :'(
por
hi please help this problem iphone 5c updating stuck the logo?t.q
por
Such in this situation. you'd better find a effective solution to fix the problem .
if you have no idea to do , maybe you can try this tutorial .
You just need to install this app and connect your iPhone to computer ,then run the app on computer , is can help you fix the iPhone stuck in recovery mode
https://www.tunesbro.com/iphone-stuck-in...
por
Exibir mais 1 comentário
Hey Lennert,
Have you tried RecBoot? I have used it on multiple occasions. Hope it helps:
http://www.cydiaos.com/download-recboot/
Pontuação 2
2 comentários:
I have tried it, choosing "exit recovery" rebooted my device but it went back into itunes logo recovery mode... Using the option to go into recovery doesn't seem to change the state of my device, it stays in itunes logo recovery mode... I'll try to use it again with the link you provided in a few hours and I'll update or it worked now...
Thanks for the reply :)
por
Can you try kicking the device out of Recovery Mode by doing the following when your phone is on and showing the iTunes logo and USB cable.
1. Hold the power and home button at the same time until the screen goes black.
2. When the screen goes black, release BOTH buttons and then immediately press and hold the POWER button until you see the apple logo and then let go of the power button.
This is usually the way you get an iPhone/iPod/iPad out of Recovery Mode without restoring.
por
What is the history of this device?
Has it ever seen water? Suffered a big drop? Have you ever opened it, removed the screen, removed the battery etc? Used non-Apple chargers?
What were you doing just before this problem started?
These details will help point us in the right direction so that we can give you an answer.
I will come back and edit/update this answer when you give me the history.
jessa
Pontuação 2
6 comentários:
Hi
I opened the phone for the first time when this problem started (to dis and reconnect battery) i noticed al of the indicators were still white so the phone hasn't seen any water... Al parts are original as the phone hasn't been opened before i disassemble it... I noticed the data cable wasn't original but i did some research and the cable (ifrogz) is a good replica and doesn't damage the phone. I did use a original data cable to charge it over night and try to do the restore wich keeps failing with error 14. I don't think the phone has been dropped as it is in perfect state (no cracked screen, no dents in body,...)
Thanks for the reply and i hope you can help me out!
por
Okay, I see that you are not going to give me the history, so I will take my best guess regardless. I will assume the history is "not remarkable, problem just started one day"
Your problem is a failure of the U2 chip. U2 controls the charging logic and is well known as a design flaw in the iPhone 5. This chip is very susceptible to damage from voltage fluctuations in non-Apple chargers, especially car chargers. The symptoms of U2 failure can be: rapid battery drain, auto power on at battery connect, no usb detect, fake charging, and inability to charge a battery that is below 1% at all. To me, it seems reasonable that an 'out of the blue' problem like this in the absence of any other insult really points to U2 failure just because it is so common.
I would expect that some U2 failures would cause an inability to restore due to problems with U2's management of the sub interface.
por
Ha! Thanks for your history--you must have been typing it as I wrote my answer. I'm still going with damaged U2 as most likely here.
por
sucks to be me then :p HA. sorry for the late answer. (time difference, i live in Belgium - Europe) from what I've read a damaged u2 chip has problems like "not booting up when putting charge in -- mine goes to recovery mode when i put my charger in"
so mine doesn't really give me direct symptomes of a damaged u2 chip... I'll keep it in mind so when I give up i still can sell every part except for the moderboard
por
I have a U2 failure board here that boots to recovery mode just like yours...but I could be wrong.
por
Disconnect battery and reconnect now don't turn on
Plug in charger to power it up when you see the apple logo quickly disconnect the charger and see does it boot up
Pontuação 0
1 comentário:
hi,
i just tried that and it just goes back to the recovery mode with itunes logo and usb cable displaying...
i posted the full itunes log, hopefully you can give me an other possible solution...
thanks!
por
1. Delete the previously down*loaded software update file which you will find in this loca*tion depend*ing on your system:
Mac: /users//Library/iTunes/iPhone Soft*ware Updates
Windows XP: System Drive:/Doc*u*ments and Settings/Application Data/Apple Computer/iTunes/iPhone Soft*ware Updates
Windows 7: System Drive:/Users/Your Username/App Data/Apple Computer/iTunes/iPhone Software Updates
If you faced the error while upgrading your iPad or iPod, the last location path will change:
../iTunes/iPod Software Updates or ../iTunes/iPad Software Updates
2. Now, restart iTunes & begin the update again. This time iTunes will download a fresh copy of software update file.
1. Re-download the IPSW file.
2. Now, restore to this newly downloaded IPSW file via iTunes.
Best of luck.
Pontuação 0
3 comentários:
Already Tried that, didn't work...
Also downloaded the ipsw from another website and used that ipsw to restore, same error 14...
Thanks for the reply, any other solution you think that might work?
por
Please try with other dock connector(charging) cable because it may be mailfunctional.Try with other usb port and remove extra usb connections.
por
Jay,
Already tried different - original - cable on 2 other pc's... going to give me mac a try this weekend...
thanks for the reply
por
You can enter DFU mode to fix iPhone stuck in recovery mode or restore mode:
# Plug your iPhone into your computer with a USB cable.
# Turn off the iPhone.
# Hold the Power button for 3 seconds.
# Hold the Home and Power buttons for 10 seconds.
# Release the Power button but keep holding the Home button.
# After about 15 seconds you will be alerted by iTunes saying that it has detected a device in Recovery Mode.
Pontuação 0
Hi Lennert,
Have you tried RecBoot for Windows and Mac? Here is the Guide to Download Recboot1
Pontuação 0
1 comentário:
nmlokesh, read the accepted answer by the OP!
por
None of this works. My phone has not hit water or anything else. I simply plugged it into Macbook Air to charge it and suddenly nonworking IPhone 5S.
Phone is about 2 years old at most. Never had trouble till now. Help!
Pontuação 0
My iphone 5s still appear logos ony.after turn on ....what can i do
Pontuação 0
I think this is probably a software problem, as described in the how to fix an iPhone stuck in recovery mode article. Maybe you should check out whether your firmware file is compatible with your iPhone version. While error 14 occurs, there are some solutions you can try to fix it, such as use a new USB cable, restart your PC, restore the beta firmware, etc. If this is useless for you, you could try the FORecovery iOS System recovery tool to help you. I hope this helps. Good luck.
Pontuação 0
Adicionar a sua resposta
Lennert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 131,098
