Ir para o conteúdo principal
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
Battery Temperature Sensor Error
I replaced my MacBook Pro Battery and after running ASD i got the following error:
[09/08/14 12:56:12] Temp (TB3T) - Battery temperature (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[12:56:12] ERROR -- 1 [Unable to read sensor] -- (-1.00) TEST FAILED
Can anybody help ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Only you know if you damaged any connectors or components on your logic board during the DIY repair.
Go over all your connectors/connections again... many times DIY find that what they "thought" or "believed" was a proper connection was not square or "snapped in".... sometimes ribbon cables were not unlocked or relocked... or the ribbon not fully inserted in the connector.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Christos M será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 796
