Ir para o conteúdo principal
The Olympus E-510 (called the Olympus EVOLT E-510in North America) is a 10-megapixel digital single-lens reflex (DSLR) camera marketed towards the “prosumer” or “hobbyist” markets. The Olympus E-510was released in March 2007.
13 Perguntas Visualizar todos
Need to reset camera date when change battery
Why do I need to reset the camera date every time I change the camera battery.? Is there any internal battery that I need to replace? Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I originally posted an answer that said these don't likely have such batteries. I've since learned differently! However, I was unable to find anything about your specific camera's battery location. If it has one, it's a fairly tightly-guarded secret (or my Google-fu has gotten weak). Might see if a local camera expert might be able to tell you without having to charge for a full repair. I know it's been a while, so my apologies for the previously posted misinformation. I hope you got it all figured out!
por
Adicionar um comentário
1 resposta
Pergunta mais útil
画像はE-420ですが、メイン基板を取り外し裏側にリチウムイオン充電池があります。オリンパス機だと似たような位置にあると思います。
刻印は621です。
Esta resposta foi útil?
Pontuação 1
3 comentários:
Good answer! For those of us who don't speak Japanese, here's the Google translation of Shinobu Sato's post:
The image is E-420, but the main board is removed and there is a lithium ion rechargeable battery on the back side. I think that it is in a similar position if it is an Olympus machine.
The stamp is 621.
por
@dadibrokeit That's wonderful news - how does one get there?
por
@terrywilcox1795 Teardown information for SLR cameras is notoriously hard to come by. All I could find for this one is a guy who is showing how to replace the power button; not what you're looking to do, but the instructions will at least get you to where you can see the main circuit board that needs to be removed.
https://genewoo.wordpress.com/2011/03/05...
por
Adicionar a sua resposta
orcadyl será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 29
Duração total: 843
