Ir para o conteúdo principal
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
39 Perguntas Visualizar todos
Black screen Huawei p7
My huawei p7 has a black screen and it doesnt respond anymore when i hold the power button it vibrates 1 time and when i put it in the charger my red light works on the phone and i dont know what to do because my warrant is not valid anymore somoene can help?
Esta é uma boa pergunta?
Pontuação 22
20 comentários
Similar problem. The phone does not power on, I just have the front led flashing a red light, then an orange one , and eventually a green light.
por
I have the same problem.. please help!
por
Me too have same problem... I am worrying a lot. Just used for a month and now no more use :(. Even in warranty, I am in USA and no service center too :(
por
Buddy, the screen itself not turning on but inside I feel it is functioning, if some one calls it is ringing but I could not seen anything in display. It is totally black
por
Exibir mais 15 comentários
Adicionar um comentário
10 respostas
Pergunta mais útil
I had the same problem and just opened the sim and sd cards and put them back in again. It came back on again. What a relief!
Esta resposta foi útil?
Pontuação 6
7 comentários:
Thank you so much. Problem solved.
por
i tried but same problm
por
worked as soon as i took out the cards
por
I will try this, I hope it will work
por
i have tried all the methods nothing worked even toke the battery out nothing work still the phone is working but black screen
por
Exibir mais 2 comentários
my phone have a this problam
helllllllp
Pontuação 0
1 comentário:
I had the same problem.my phone doesnt switch on and its only blinking in red
Please help.thanks
por
Remove the back cover to check if the screen connector gets loosen and try to re-connect
Pontuação 0
2 comentários:
and how do you do that?
por
yeah his right, how can you remove the back cover ?
por
guyz my screens only shows up during calls and when i unlock my phone. After unlocking my phone the home screen gets black and can see the bottom 3 options and can use the top slide as well but can't assess the app's that are on home screen ??? plzz help me out
Pontuação 0
lol i just changed my home screen style from top slide setting and issue resolved : D now.
no more black home screen............... wew
Pontuação 0
1 comentário:
really, that great
por
You need to flash your Huawei P7 Device using P7 Firmware, download P7 Firmware from google, and flash with that. Can you access to "Recovery Mode" ?
Pontuação 0
I can her mine but I can't see nothing
Pontuação 0
my Huawei p7 lite is black screen can’t open but I charge the it have the led light and sound others things is nothing just the screen always black screen.how to fix it
Pontuação 0
1 comentário:
I have exactly the same issue ;(
por
Please my Huawei Phone is on the power button isn’t working, the phone is on, as I keep hearing notifications but can’t open it, HELP!!!
Pontuação 0
ASSALAMUALAIKUM in my p7 phone there is a problem the problem is my phone is not charged and not open some days ago my phone is on but there is a line colour green but my phone is not on plz help me
Pontuação 0
Adicionar a sua resposta
MsMoha1997 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 20
Duração total: 31,919
