Why does my replacement battery not work?
I replaced the A1322 battery in my 13" Macbook Pro (mid 2009) and the battery icon has a black "X" in it. It will not charge and the computer says "no batteries available."
I reinstalled the old battery and it worked fine. What should I do to get the new battery to work?
Esta é uma boa pergunta?
1 comentário
I have the same problem. Bought a replacement A1322 battery here on ifixit for my macbook pro, early 2011 model. Followed all instructions to install. I still have the same battery indicator I had with the old battery:
The icon shows the battery plugged in, with the words "(Not Charging)"
I took the whole thing apart again, and checked: the connector is as tight as it should be, properly seated. Still no battery charge.
The second answer to this post is definitely for the macs with the easily removable batteries on the bottom of the case; not for the unibodies.
(However, if you've got one of the older MacBooks, try it. It works on my phone when it won't charge!)
por rileybk
