Ir para o conteúdo principal
Rear Camera does not autofocus after battery replacement
Hi,
Last week I replaced the battery on my iPhone 5 by following the guide and did not have any issues at the time. I am now finding that my rear camera does not autofocus on close up objects.
I have already opened the device and reattached the 3 cables at the top (digitiser etc.) to see if this made any difference but it has not.
I have also tried tapping and banging the phone as directed elsewhere on this site but again no joy.
Does anyone know what could be causing this issue?
Any insights much appreciated!
Esta é uma boa pergunta?
Pontuação 2
3 comentários
Have you checked for a spec of dust on the lens? This will usually take it out of focus.
por
I ran into the same issue after changing the battery on an iPhone SE. My suspicion is that some of the adhesive remover got into the camera module. Once it evaporated, it might have left behind some adhesive and now the mechanical focus inside the lens is stuck.
por
I had the same experience and have the same suspicion as Jonathan Flower--I squirted some isopropyl in to soften the battery adhesive, but it got everywhere. Camera initially had liquid droplets in it, then once it dried it did not focus properly again. I'm now opening the phone again to install a replacement camera ... :(
por
Adicionar um comentário
3 respostas
Pergunta mais útil
The rear camera has nothing to do with the three cables at the top of the logic board - that beeing said, if the front facing camera malfunctions, the camera app won't start at all. Seeing as you apparently can open the camera app, this is not the case.
The rear facing camera has its own flexcable/connector on the opposite side of the logic board. I guess you didn't remove the logic board in order to replace the battery?
Is the camera able to focus on things that is not up close? All cameras has a minumum distance that they are able to focus on..
First of all make sure that there is nothing on the lens that would make the camera try to focus on that.
The next step would be to do a hard restart (holding the power and the home button untill the phone restarts)
Last step would be to replace the camera.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your prompt and detailed advice Soren!
I have used the camera to take photos of close up text in the past however now it is very blurry.
It does seem OK when taking normal photos so dust on the lens is the next thing I will check.
Thanks for your help.
por
Hi Allan, I know this thread is old now. But how did you go with your Iphone 5 camera?
I had just had my battery replaced and its doing the same thing, won't focus.
Pontuação 0
Hi, I just have the same issue and the camera only focus when the front panel is not secured against the phone. If I mount the screen the problem appears again and the autofocus didn't work. I don't know if the problem exists before the battery replacement because I bought the phone and then replace the battery without further testing the camera.
Any help?
Pontuação 0
Adicionar a sua resposta
Allan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,632
