Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Touch does not always work
When touched it does not change or place letter in box, or it places to many letters. There are times when it keeps changing screens without anything being done then it gets stuck on a screen.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Did this happen after you replaced the screen
Esta resposta foi útil?
Pontuação 0
2 comentários:
No this did not happen after changing screens. This is a 1 year old iPad mini.
por
I had the same thing happen after I replaced the screen and digitizer but don't know what is wrong.
por
This is solved with a replacement screen.
To avoid this problem:
1.) do not allow the digitizer flex to fold and make a crease
2.) properly tape both the bottom of the digitizer and the home flex to look like the original screen using kapton tape
3.) use an original quality digitizer--plan to spend $40 wholesale, $55 retail--others are low quality
Note:
If you've recently replaced the screen, check for common damage to the digitizer flex socket on the board
Pontuação 0
Adicionar a sua resposta
Tony será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Ao todo: 154
