Ir para o conteúdo principal
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
laptop keep restarting when using
when working and using my laptop it restart by itself
and loose my work
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
All modern processors has a safety feature that shuts down the computer once the processor reaches a certain temperature, to ensure that the processor is not damaged.
Typically the processor overheats if the air intake vents are blocked - either if you are using the computer on a pillow, blanket etc. which restricts the air flow into the fans or because the fans are blocked by dust.
If you are up for it, I would suggest that you clean the fan. The procedure is not that complicated and can be done by almost anyone :) As an example, you could follow this tutorial: https://www.youtube.com/watch?v=nv8rZYut...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
nazih hudhud será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 178
