Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Perguntas Visualizar todos
unit wont turn on and wont charge!
The unit wont power up by battery or by wall plug and when attached to the charger the charging light comes on for about 10 seconds then shuts off i have tryed 3 differnt chargers they all work fine on other ds lites
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
From what I am reading it seems to be in need of an electrical repair. The fuses have blown and will need to be replaced. There you tube videos that show where and what to replace as well as fuses for sell on eBay that are the proper size (0603) and current (1-amp) they are surface mounts so a certain level of soldering capability will also be needed to fix the problem.
Esta resposta foi útil?
Pontuação 1
I have the same probelm with a like new DS Lite. Why do the fuses blow out? Thanks Eduardo
Pontuação 0
Adicionar a sua resposta
nanabugbaby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 3,242
