Ir para o conteúdo principal
Digitizer LCD problems after repair
I replaced the digitizer LCD assembly and there are 2 thin lines running down the length of the phone about 1/4 inch apart. (on the right side of the phone running from top to bottom) In between the lines, the touchscreen doesn't work. Is this a bad part or a connection problem?
Thanks,
Karen
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
I see this all the time. Try re-seating the connectors. Sometimes they seem to be all the way in but are not. That fixes it most of the time. If it doesn't then yes, you have a defective part.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks, will do!
por
also make sure your wearing esd gloves or wrist strap, ive killed a couple of display assemblies from shocking them but none since ive gone the glove method :)
Pontuação 0
As PDM says, reconnect the connectors, and also disconnect the battery to do e power cycle. Also check for dust and dirt in the connectors on the motherboard :-)
Pontuação 0
Adicionar a sua resposta
Karen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 111
