Ir para o conteúdo principal
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Perguntas Visualizar todos
charger won't stay connected and charging
I just replaced a worn charger thinking it would solve my issue, but it hasn't. When I plug the charger into the side of the MacAir I have to fiddle with it up and down to get it to connect and properly charge, and then it will sometimes lose that connection so I will get a prompt that my battery is low again.
I have tried using a dry, clean toothbrush and scrubbed the new charger and charging part on the side of the Mac, but it did not improve the problem at all.
I've looked in the guide to see if I could replace that part, and I do not see it as an option.
Please help
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like your I/O board needs replacing. Here's the IFIXIT guide: MacBook Air 13" Mid 2011 I/O Board Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rob Donovan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 5,083
