Ir para o conteúdo principal
display problem after battery change
Hello,
i tried to change the battery of my phone. Everything works (I hear sounds etc.) But my display looks like it crashed with the floor..
It looks very similar to this picture :
http://www.pocketpc.ch/attachments/apple...
Do you have any advice what this could be ?
Thanks !
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
First off did you take the screen out when replacing the battery?
There is a couple videos I see on YouTube about replace a battery in 2 minutes by some guy in my opinion no1 should change a battery like this you only asking for trouble..
It looks like you have a damaged lcd if you never took screen out then it's definatly that ..
If you did take screen out go back take connections out and reseed an try again.
If you get the same outcome you need a new screen
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Compaq será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 91
