Ir para o conteúdo principal
Repair guides for the MacBook.
3787 Perguntas Visualizar todos
Pergunta encerrada
What screwdriver for opening MacBooks
hello iFixit,
i wanna buy a screwdriver but only the one who's used to open macbooks. So I'm asking here, is the Phillips #00 Screwdriver the correct one for macbook or am I wrong? Also, I need to know if iFixit sells screws for macbook because I lost most of mine when I opened my macbook.
thanks all!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What are your intentions after you get the bottom case off? Or are you just trying to keep it on?
por
Friends often ask me to add or do some replacement of hard drive or memory for their macbook. the matter is, I have to borrow friend's screwdriver to do so. I cannot borrow theirs forever.
Thanks @LAS. yes, these are exactly what I was searching for. The screw set for macbook are quite expensive :/
por
Adicionar um comentário
1 resposta
Solução escolhida
Which model of MacBook is it?
Esta resposta foi útil?
Pontuação 1
2 comentários:
it's the mid-2010 model
por
MacBook Pro Unibody Lower Case Screw Set
That are the right screws if you own a 13" or 15" model and this is the right screwdriver:
Hope I could help you, if so please score my answer. :-D
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 230
