Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Is PS3 Dual Voltage
I have 40 gb PS3 US version. Manuf. date is Nov 2007. Serial number is CECHH01. I need to know without opening the case is this system multi-voltage even though 110 is only listed voltage on the outside label. I am US Military and moving out of the country to foreign location.
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Michel did the older model work?
I was under the impression hat it only works with newer models the older ones are not dual voltage?
por
@Baggie, all of them are.
por
Adicionar um comentário
2 respostas
Solução escolhida
As far as I can tell the PS3 is dual voltage, I just checked around on some other forums and am hearing the same thing.
Good luck and thank you for your service!
Esta resposta foi útil?
Pontuação 6
1 comentário:
+1 for double-checking your answer.
por
Yes, it is; I have Ntsc-J model and I live in Estonia/Europe - no problems :)
Pontuação 2
Adicionar a sua resposta
Michael será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 5,928
