Adding hard drive in my time capsule
I have a time capsule without hard drive.
Can I set up an outside hard-drive I have inside or I have to use it with USB port of time capsule
Esta é uma boa pergunta?
Are you sure you have a Time Capsule Vs an AirPort Extreme?
Both look alike (same case & ports on the outside). The Extreme model is missing parts internally to support the HD the Capsule model has.
If you have an Extreme unit it's not worth the effort in locating all of the needed parts to converting it over to a Capsule unit.
Esta resposta foi útil?
Thanks
I have the airport extreme
If this answer answered your question please remember to rate (score) and mark it accepted.
Accepted and site very helpful
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,926
