Ir para o conteúdo principal
All screwdrivers manufactured by iFixit and sold on iFixit.com
Are the TR10 and TR8 screwdrivers interchangeable with T10 and T8?
Hi!
Thank you for your great guide! I have a question regarding the Torx screwdriver sizes. I own a toolset that includes T6, T8, and T10 sizes as well as a few others. In your guide, it is listed that a "TR10" and a "TR8" screwdriver is needed. After watching several videos pertaining to hard drive replacement, many people claim that they are using the standard T10 and T8 sizes. Is there any difference between the "TR" labeled screwdrivers and the standard "T" ones? I don't want to have to buy these two screwdrivers if the ones I currently own will work. Please advise. Thank you!
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Solução escolhida
Here's a breakdown of the more common bits:
The TR (Tamper Resistant) Trox screw has a pin in the middle of the hole so a standard Torx bit can't grab the screw.
Esta resposta foi útil?
Pontuação 7
3 comentários:
Thanks! Great diagram. I just put in an order for the TR Torx screwdrivers.
por
The TR drivers might be able to work with standard Torx screws, but not visa versa. In about twenty years of working on Macs, I have never actually needed any of my TR drivers. None of the repair-guides I have found acutally calls for a TR driver - perhaps Sebastian has encountered a typo?
por
Johann, Mac Mini 2018 is using TR6 screws.
por
Adicionar a sua resposta
Sebastian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 101
Ao todo: 26,047
