Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
MacBook A1278 Screen issue
Does anyone have any idea what wrong with my Mac?
Esta é uma boa pergunta?
Pontuação 1
3 comentários
This question was migrated from http://meta.ifixit.com/Answers.
por
That's actually a MacBook, not MacBook Pro
por
I do agree with Dan, but I would check to see what an external monitor shows first....
por
Adicionar um comentário
1 resposta
Solução escolhida
Your lid must have gotten a good hit. What has happened here is the driver logic on the back of the LCD panel has broken free from the glass so the area that is black is not getting the signaling to de-phase the crystals so the back light is not able to get though. Here's a write up and a model as reference: How LCDs Work.
Sadly you'll need to replace the display. You may want to consider the easier way here of just replacing the complete lid unit Vs the LCD panel alone. Here's the two IFIXIT guides that explain whats involved:
While the complete assembly is more costly there is less risk of damaging anything, unlike the panel replacement which while being cheaper needs more tools and skills as you can break the cover glass.
Imagem de MacBook Unibody Model A1278 Display Assembly
Guia
MacBook Unibody Model A1278 Display Assembly Replacement
Nível de dificuldade:
Moderado
Imagem de MacBook Unibody Model A1278 LCD Panel
Guia
MacBook Unibody Model A1278 LCD Panel Replacement
Muito difícil
2 - 4 hours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Brian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 372
