Ir para o conteúdo principal
Modern rebirth of John Cooper's classic automobile, made by BMW.
13 Perguntas Visualizar todos
Cabin air vents not supplying any air.
I own a 2004 Mini Cooper S, and no air will come out of the dashboard air vents. All air seems to be vented through the defrost vents. I have checked all fuses, cabin air filter, and even tried the "off button/ '+' " system check with no faults found. Any suggestions would be welcome.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Most cars have either a cable or a motor system to alter the air dampener valve/s.
When you alter the setting do you hear any noise of a motor or the thump of the valve closing? My Ford had foam rubber as a seal around the dampener door it got sticky so it wouldn't open.
You may need to locate the valves under the dash heater/cooler box. Try moving them manually.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,372
