Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Why does my phone now not charge at all after dock replacement?
My phone originally would only charge when turned off. So I replaced the dock, and headphone jack (for a separate issue). Now it will not charge at all. Any ideas? Did I forget to connect something, or not connect it back properly? I am bumfuzzled.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
The dock connecter plugs into the logic board and is cover by a plate which has 2 screws in it, (see image) aslong as you connected that connector it should charge unless you have a faulty dock connector.
try another replacement dock connector.
hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jema será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 50
