Ir para o conteúdo principal
Both the power and home buttons not working after screen replacement?
I replaced the screen + LCD/digitizer on my white iPhone 5, and after both the power and home buttons aren't working! I checked all the connections and the only thing I can think of is I wanted to disconnect the battery just to be safe and I tried to remove it for some reason after I disconnected it. I broke off that little plastic tab that says "Authorized Service Provider Only". I then tried to pry off the battery in the same spot and I might have damaged the thin skinny black ribbon cable that runs alongside the right side of the battery. Thanks, I need help.
Vince
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Right under that long skinny black cable is componants and you have for sure knock one off them off .. You will need some1 with soldering skills I would lookup Jessabethany on this site she can do this repair
Esta resposta foi útil?
Pontuação 0
Does it turn on? I am assuming that by them not working you mean its not turning on? Did you plug it into a computer to see if it will turn on? If not then you probably damaged the battery cable.
Pontuação 0
Adicionar a sua resposta
Vince Parisi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 96
