Ir para o conteúdo principal
Repair your Dyson DC 14 vacuum cleaner with a part replacement guide.
Brush bar is extremely noisy
If I use the telescope handle, it works fine but when I want to vacuum the floor and I turn on the brush bar, it's extremely loud; like it's screaming.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
If your Dyson vacuum is emitting an unusual smell, see the Dyson Ball Animal Emits Unusual Smell or Noise problem page for possible causes and solutions.
No guarantees, but mine was producing a loud screeching noise also.
I removed the brush bar and cleaned the ends where it contacted/mounts in the head.
I then used petroleum jelly (very, very lightly so as not to create a gunky mess) around these contact points where there is a lot of friction.
Esta resposta foi útil?
Pontuação 1
I had to replace the brush bar motor
Pontuação 0
Adicionar a sua resposta
jsifferath será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 10,228
