LG G2 Screen compatibily VS980 D800/2
Hi,
The digitizer on my LG has broken and so I am now on the look for a replacement digitizer/whole screen.
However, I have the VS980 model number. Do all the G2 models have interchangable screens, or must i get the screen that specifically states it is compatible with the VS980 model, as many sellers simply only state its compatibility with the D800
Esta é uma boa pergunta?
2 comentários
Pls, let someone help! My lg g2 vs980 digitizer has broken everywhere, which one do i use and where do i get it in NigeriaNigeria?
por Ab Zakariyya
Update (long overdue):
The VS980 and D800 are different models and thus have different flex cables. If attempting to repair yourself, be sure to buy the correct screen for your particular model.
Also, separating the LCD from the glass/digitizer is not an easy task at all. Very high chance of damaging the LCD itself (as I learnt the hard way). But perhaps those more experienced (and with proper equipment/tools) may have better luck than I did.
I personally did not find it was necessary to purchase the frame as the ribbon cables simply just slide through designated slots on the frame assembly itself. The only advantage would be minor cosmetic benefits as only the edges are visible once the phone is reassembled.
Thank you for the responses. Hopefully this may help others who also encountered similar problems :)
por Talha Bhatti
