Ir para o conteúdo principal
The Sony Digital Projector model VPL-ES1 is a multimedia projector produced by Sony between 2003 and 2005.
6 Perguntas Visualizar todos
A Corner of the Mirror in front of the lamp is damaged
Hi,
Thanks for showing internal parts of VPL-ES1. I have ES2 which is similar to ES1. Few days back its lamp stoped functioning.
I removed lamp as shown in step 2 & 3 (Sony Digital Projector VPL-ES1 Teardown).
But while removing it damaged corners of the mirror, which is in front of the lamp.
The mirror is shown in step 19 (Sony Digital Projector VPL-ES1 Teardown).
If I don't change the mirror, will the image quality affect after putting new lamp in the projector.
Local Sony enigineer says it will not affect.
But i don't to buy a new lamp and later realize that projector is not working because of broken mirror.
Please reply.
Thanks and Regards,
Rahul Borgaonkar, India
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
like always -> the dose makes the poison
depending on the size of the damage - wou will see or not see the damaged corners. but in common - optics tending to deliver unsharper details in the corners - so many problems will never be seen - and some optics are larger than the area the are reproducing - so i would trust the sony engineer and would change the lamp
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rahul Borgaonkar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 766
