Ir para o conteúdo principal
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 Perguntas Visualizar todos
Not getting cold at all
We have a 10-15 year old fridge that we moved from our lake place to home. It worked perfectly before we unplugged it to bring it home. It sat in our garage for about a week, we then plugged it in and it won't cool at all. The light comes on inside, but it isn't getting cold. I don't understand because it worked perfectly before we moved it? Any help would be appreciated. Thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
There are several possibilities the may be causing the problem.
Refrigerator's need to be on their on power circuit, if there is something else on the same circuit the fridge motor will not have enough power to run and may burn out. Or the outlet the fridge is plugged into may be bad. If you have a heavy duty extension cord you can plug the fridge into a different circuit, do not use a light extension cord it will not be able to handle the amount of power the fridge will draw and may catch fire.
If the fridge was laid on its back or side when it was moved the compressor may have been damaged.
The fridge is old the circuit board may have gone out, or the hard start capacitor may be bad. If the hard start capacitor is bad you should hear a clicking noise coming from the bottom of the fridge at the back.
Hope this helps
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you so much!
por
Evaporator Fan Motor
Pontuação 0
1 comentário:
Thank you! We will check into this!
por
Adicionar a sua resposta
Tammie Rothenbuhler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 142
