Ir para o conteúdo principal
The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
149 Perguntas Visualizar todos
Can I upgrade from 4GB to 8GB RAM memory?
I have a MacBook Air 11" mid 2013 that came with 4GB RAM and 128GB hard drive. I want to upgrade the RAM to 8GB so I can run Vmware more efficiently with windows 8.1 and other software that don't run on the mac-side.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Solução escolhida
Sadly, no
Apple soldered the RAM to the logic board. You can upgrade the SSD! It's replaceable.
Esta resposta foi útil?
Pontuação 5
2 comentários:
Could you replace the entire logic board with one that had 8gb of RAM rather than the original 4gb?
por
Swapping out the logic board with one that has 8 GB of RAM is possible!
But, the cost factor for doing this then becomes the issue. I would recommend locating a used system which is newer as being a better investment.
por
Adicionar a sua resposta
Rich será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 4,773
