Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
choc on back panel near the trackpad
Hi, i just want to ask you because i have a little shock (i made a mistake on my translate) on my macbook pro 13 retina on the edge near to the trackpad.
I have no problem with the computer it's an esthetic question.
Thanks
(I edit my post because of wording mistake)
Esta é uma boa pergunta?
Pontuação -1
3 comentários
What is choc?
por
Steeve, as in you have a dent in your case from the shock (fall etc?)?
por
Well I guess it wasn't Chocolate was it ;-}
All computers get banged up over time. Nothing you really can do about it. Remember your system (while expensive) is a tool and tools do get worn over time.
If you think the damage will interfere with its operation then you should fix it if you can.
Can you post a good image of the damage for us to see?
por
Adicionar um comentário
1 resposta
Solução escolhida
Chocolate? If that is what you have caught in the grove of the trackpad a cotton swab (Q-Tip) with some Isopropyl alcohol (85% or better) should do the trick of cleaning it. Only moisten the cotton you don't want it wet as you will push the alcohol into your system which you don't want.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Steeve será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 86
