Ir para o conteúdo principal
everything is working fine except from the home button
After replacing my iPod's front panel everything is working fine except from the home button, it is unresponsive.
If I press the switch directly it works, but not if I use the button! May the button have been damaged during the repair?
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Under the button you see a spring. Sorry don't have a picture right here. The button only shorts this spring so the two gets contact. Try (very carefully since it can easily break) to lift up the spring so it is easier to short it. I remember I had the same problem and the spring was broken so I had to lift up what was left so it came in contact with the button. Don't remember if there are two springs but you see what the button is supposed to make contact with. Hope it helps!
Esta resposta foi útil?
Pontuação 1
1 comentário:
Ummm.... I can't see the spring... iPod touch 4th Gen is supposed to have it? :S
por
It's not a spring it's a little black peice that sits up slightly it's common for this to break off
Pontuação 0
Adicionar a sua resposta
luciacossio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 129
