Can I buy a replacement retaining clip for the LCD display data cable?
Hi,
I have broken the retaining clip that holds the lcd ribbon. I have tried using a bit of plastic to hold it in place and put tape over it. When I press the home button I'm getting no picture, but I hear siri in the back. I noticed when I pushed in the plastic to hold the cable secure that it looks like one of the conductor pins is loose. You can see from the image the little one sticking out. I had actually fixed the digitizer a few days before but I had broken the frame part so I had to take it apart again and put that on. So the 2nd time is not a charm.
If I need to buy something new can you suggest what and where I can find it? Thanks so much pulling my hair out now. I pretty technically oriented because I take laptops apart and put them together.
thanks!!
Esta é uma boa pergunta?
