Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 Perguntas Visualizar todos
My games will not load
I cannot play games on my 3ds. When I put a game in the 3ds does not load or even recognize the game. This happens with all games not just one particular game. I have inspected my games and the pins are not the problem. Help please
Esta é uma boa pergunta?
Pontuação 23
6 comentários
I putted a piece of paper but it didnt work
por
One of my 3ds games wont load either. I tried cleaning the contacts but that hasn't made a difference. Also none of the contacts seem broken/damaged. Anyone have any ideas to fix this?
por
Please fix it so I can load games again
por
My Nintendo 3ds’s game will not take the game like it won’t go all the way down
por
My game works fine but when I go to play it, doesn't load at all. It just stops loading 4 seconds in. It only does that for one of them, not all.
por
Exibir mais 1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
There are several things that commonly cause this type of problem:
1) The pins inside the 3DS game slot may be dirty. If this is the case then the first thing to try is to insert a game and then take it back out several times in a row (like 10). If that doesn't work then you can use rubbing alcohol and soak a q tip in it, then rub it on the pins of one of your games. After the pins are wet with alcohol insert it and take it out several times. If none of this works then try the next option:
2) If the pins in the game slot are not dirty then you likely have either a bent pin or one that has been pushed down and needs to be pulled back up. The best way to tell if this is the case is to use a good, bright light and shine it into the game slot. While the light is on it you need to take something like a dental pick and insert it into the game slot. You will see a thin metal piece that will move. You need to move this piece up so you can see the actual game slot pins. See if any are bent. You also need to look at them all very carefully to see if any of them are lower than the others. If they are then they need to be bent back up.
You will also want to look to see if there is anything jammed in the game slot. I've seen that several times too.
Both methods (but especially #2) need to be done very carefully. Someone who is good and experienced at this can probably fix it without taking anything apart. Sometimes the bottom case needs to be removed to repair it, and if it's really broken the whole game slot will need to be replaced.
I could repair this for you if you don't feel comfortable doing it.
Esta resposta foi útil?
Pontuação 30
28 comentários:
What about 3ds xl.ds games work but 3ds games won't work
por
would a pencil work instead of a dental pick
por
No, a pencil would not work. It would likely break and possibly get jammed in the slot. Also, you need something that has a curve or hook or something at the end so you can grab the pin and bend it back.
por
Can you fix mines please? I might screw up on it plus I have the new Nintendo 3ds xl the newest version of the Nintendo 3ds can you help?
por
Sure...you can contact me by clicking on my name...that will show you links to my website. Then just contact me from there.
por
Exibir mais 23 comentários
My 3ds doesn't load my games on I have checked all the pins but none of then are damaged I think pls help
Pontuação 1
1 comentário:
My Nintendo 3DS will start-up but when I try to run an application or game I get the Nintendo 3DS screen and I cannot go any further, this applies to the Systems Spanner too. How do I fix this?
por
Adicionar a sua resposta
monica será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 50
Últimos 7 dias: 233
Últimos 30 dias: 1,084
Duração total: 281,192
