Ir para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
590 Perguntas Visualizar todos
Pergunta encerrada
MBP cannot start. Powers up hdd then shuts Down
Hello i was browsing the internet on my mbp (plugged to power) when it suddenly went dead. When i try to turn it on, it powers up for maybe 2-5 secs (ligth in the White led, hdd starts spinning) then shuts Down. It never makes it past Black screen to the Grey screen.
I have put ssd in the computer in the normal hdd spot and mounted hdd in the spare where dvd. Drive usualy sits, using an adapter. This has however been working flawless since april.
I have tried resetting smc by pressing L-shift + ctrl + option and power Button at the same time.
Cannot reset pram either.
Tried checking hdd and ssd connections to mb, as i had read that it could cause these symptoms.
Any advice on what i could try to do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Torben;
Is your secondary drive bootable? If so, restart, and hold Option key when chime sounds or screen turns on. After a few moments, a list of bootable devices will appear.
- If a bootable device is available, select it for boot, and troubleshoot the problem drive.
- If not, boot to an external bootable backup drive on USB or Firewire port and troubleshoot.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Also - you did not mention if MBP running on battery or mains power. Make sure you are on either a well-charged battery or using the power adapter.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 85
