Ir para o conteúdo principal
Repair for LED, incandescent, and other handheld electric light sources.
27 Perguntas Visualizar todos
Where are the hi/low settings on a Rayz LED Flashlight?
I have a Rayz flashlight.It says it has a high and low setting. how do i use the settings? idem number 180900
1000 lumens
Esta é uma boa pergunta?
Pontuação 2
1 comentário
We have the same question....no directions with this flashlight and we are unable to get the low setting?? TY
por
Adicionar um comentário
7 respostas
Pergunta mais útil
I finally figured it out (with help) after many clicks and playing around with it. I was starting to assume that it was typo or something on the packaging but the two settings actually exist.
You 1) turn it on 2) gently hold in the power (without it clicking). You hold it in about half-way. It's tricky because both settings are close and hard to tell the difference, but the lo-power is there.
Esta resposta foi útil?
Pontuação 5
4 comentários:
Way to go on answering a very tough one!
por
Sorry, I don't see any difference when following this procedure.
por
Thanks for spending time figuring it out
mdr903
por
Kinda repeating what Jason said but I thought I'd give my two cents. My father bought a few of these flashlights and found them at True Value for right at $20 each. Seem to be done decent lights and blows my super expensive StreamLight away. There actually are hi and lo settings but it's barely noticeable. While the light is powered on just gently tap the power button barely depressing it without turning the light off and you're in low setting. Again, the difference is just barely noticeable...
por
Alright, here's another question on the same item. I own a RAYZ flashite and it's recent decide to BLINK when on and I can't get it to burn steadily? Any idea. I can't seen to find a company website or a distributor on the web.
Pontuação 0
2 comentários:
I found the distributor (Promier - 815-223-3393) and they are sending me a replacement. There is no fix!
por
Thanks for the phone #, my unit stopped working and they are sending a new one. Great customer service.
por
Actually first click is bright on 2nd click is off 3rd click is dim on and it keeps alternating. Try it you will see a slight difference in brightness. Hence the 3 terminals on battery pack.
Pontuação 0
You switch between the high & low settings using the tail switch. One click turns it on to the high setting and rapidly clicking a second time gives you the low setting. However there is not much difference in the intensity between the two settings.
Pontuação 0
Thanks for all the help here, I had the same question. Has anyone found that turning it focuses it all?
Pontuação 0
Does anybody know how many watt the led is?????
Pontuação 0
turn the flashlight on and then press the button again for low beam.
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 4,187
