No start, led#1 on, led#2 flashes, then both out
Hi Everyone,
No start, nothing when press power button. Looked at leds.
Plugged imac into power and led#1 comes on. When press power button, led#1 goes out.
Replaced power supply.
Now, plugged imac into power and led#1 comes on. When press power button, led#2 flashes on, screen flashes briefly, then both leds go out.
Would anyone have some insight into this problem?
thanks,
Dave
Esta é uma boa pergunta?
3 comentários
I did not do the multimeter tests yet. I emphasize that I have replaced the power supply with a new one from a sealed package. There was no change with the new PS, except maybe now there is a little twitch of the fan. But I might not have noticed that with the original PS.
por dgarboczi
I'm back on this project after 6 months. I get LED #1 upon plugging in, then when turn on, #2 and #3 come on briefly and then all three go out. I would like to test the power supply with voltmeter, but it's the 614-0405 power supply for the A1225 24". There are two rows of six output terminals (12 total). The "iMac Intel 20" EMC 2210 Power Supply Output Voltage Test" shows one row of 10 terminals. Can anyone tell me what volts I should be seeing on which terminal? The terminals are numbered on the board.
thanks,
Dave
por dgarboczi
I replced a CPU (upgrade to i7/3.4 GHz) . Got LED 1 ON, LED 2 briefly on then off (cycles) , measured everything. had to find out one or more RAM modules weren't seated correctly or were dirty at contactlevel. Cleaned, reseated firmly, Got it all back up working again , was about to throw it out the window :)
por Hk Barry
